Inv 2009 will not work with content in ADMS 2008.
You need to upgrade to ADMS 2009.
You may want to read this document
"CC_for_Inventor_2009_side_by_side_install.pdf"
Located by deafult at "C:\Program Files\Autodesk\Inventor 2009\Setup\Docs"
or the install location you chose.
-Vijay I
Inv QA, ADSK
wrote in message news:5897396@discussion.autodesk.com...
I just installed Inventor 2009, when I try to add Content I get a message.
Autodesk Inventor 2009 is not compatible with the Autodesk data management
sever hosting the following server applications.
My content works fine with 2008
