Yes, it is correct. If you change the Bolt length, then the bolt has a
custom length and the Bolted Connection does not react to this custom
change. So, the hole is not updated.
Pavel Holecek
Design Accelerator - Autodesk
"Randy Knight" wrote in message news:5898944@discussion.autodesk.com...
Thanks for the reply. The Alt does the trick for getting to the custom
lengths. I am putting in a bolted connection using a point and choosing a
blind hole. If I edit an existing bolted connection and choose a different
length of connector the existing hole and thread length created by the
original connection have to be updated manually, correct?
