I'm just copying this stuff from Autodesk documentation -
2.2.4 Educational Institutional Version. If Autodesk identifies the Software as an “Educational Institutional Version” in the applicable User Documentation, You may Install and Access one (1) copy of the Software on up to the Permitted Number of Computers, only for educational purposes (as further specified in the applicable User Documentation) and for no other purpose. Without limiting the foregoing, Educational Institutional Versions of the Software may not be used for commercial, professional, commercial training or other for-profit purposes. Additionally, functional limitations apply, as set forth in Section 6 (Warnings).
2.2.5 Student Version. If Autodesk identifies the Software as a “Student Version” or “Personal Learning Edition” (each, a “Student Version”) in the applicable User Documentation, You may Install and Access a single copy of the Software on up to the Permitted Number of Computers, only for personal learning purposes, and no other purpose. Unless otherwise provided by Autodesk in the User Documentation, Student Versions of the Software may be used for a period of one (1) year from the date You first Install the Software. Without limiting the foregoing, Student Versions of the Software may not be used for commercial, professional or other for-profit purposes and may only be used by persons who qualify as a permitted user of Student Versions (as further specified in the applicable User Documentation for Your Territory). Additionally, functional limitations apply, as set forth in Section 6 (Warnings).
The CADWhisperer YouTube Channel
