Inventor Forum
2008 merge problem with qty.
3 REPLIES 3
207 Views, 3 Replies
I am merging stock numbers for banding on my parts. I can get the parts list to merge the stock numbers and total the lengths but the qty still shows the total number of parts coming from the merge.
For instance I have 2 pieces of banding each 10 in long. My part list shows banding qty 2 length of 20. I need the qty to stay at 1. I don't need 2 pieces of banding 20 in long.
TIA
inv 2008 sp2
3 REPLIES 3
johnsonshiue
Hi! You can consider using Value Substitution in Part List. Edit the Part List and right-click on the QTY column->Format Column->Substitution.
Enable Value Substitution
Where exists, use value of BASE QTY
When rows are merged, value used is FIRST Value
Thanks!
Johnson Shiue
johnson.shiue@autodesk.com
Software Test Engineer
Will this affect the qty of the other parts that are not merged?
johnsonshiue
No, it should not affect non-merged rows.
Johnson Shiue
