Inventor Forum
1 D Stress Analysis
5 REPLIES 5
536 Views, 5 Replies
1 D Stress Analysis
Hi.
As a part of my course, I am supposed to do 1 D stress analysis.
It was possible in ANSYS.
But how to do that in AD Inventor? (I can do basic 3 D stress analysis, bu I need to know how to do 1D)
So, is it possible in AD Inventor 2011 or only 3 D stress analysis is possible?
Thanks in advance for your reply.
Tags (1)
5 REPLIES 5
JDMather
What is the design geometry - can you post an example file?
Are you familiar with the Design Accelerators - beam/column/plate?
in reply to: JDMather
Hi.
My problem is, there is a beam hanging vertically, to which an axial force of 100N is applied.
Now I have to find out the elongation using 1D spar element in ANSYS.
I have to do it as 1D only.
So in ANSYS I will first select the spar element, then draw a line whose length will be same
as that of the beam and th cross-sectional area of the beam is entered seperately in a dialog box that corresponds to the 1D spar element.
So, my question is to know whether I can do it in Autodesk Inventor or not?
Please see the picture at http://www.mece.ualberta.ca/tutorials/ansys/BT/Truss/images/Lines.gif
It is simillar to this, i need to model in Autodek Inventor. I am aware that the truss can be modelled in 3 D.
Also view http://www.mece.ualberta.ca/tutorials/ansys/IT/Density/images/Deform.gif
Thank you.
kstate92
You might want to check out the FEA in AutoCAD Mechanical.
KState92
Inventor Professional 2020
AutoCAD Mechanical 2022.0.1
Windows 10 Pro 64 bit - 1903
Core i7-8700 32 GB Ram
Quadro P2000
in reply to: kstate92
Thank you very much.  This was what I was expecting.
Thank you very much.  This was what I expected.
