Inventor Forum
1.5 2 Failed to create NGEN process. 3:267
2 REPLIES 2
6885 Views, 2 Replies
I am running Inv 2008 on( P4 3GHz processor, 2GB RAM, Nvidia Quatro FX 600) which had previous Inv versions including R9 that still has its MDT 2005 installed and I can't uninstall it. it brings this error when unstalling: "1.5 2 Failed to create NGEN process. 3:267".
Another problem is that every time I launch Inv 2008 it try to configure MTD 2005, which I succeed by cancelling the configuration 3 times. see attached file for the error message.
Please help.
2 REPLIES 2
我也遇到这种问题,但我很快就解决了。我知道是什么原因造成的,是因为你的电脑安装的 Microsoft.net Framework 3.0(或.net Framework 3.5)这类托管程序遇到功能性问题或安装出错造成NGEN运行失败,因此只要你重装安装.net Framework 3.5 SP1一般就能解决改问题。如果问题仍然未解决,你可以卸载掉.net Framework 3.0后另外安装.net Framework 2.0或t.net Framework 4.0就能解决改问题。希望这个回答能帮助到您,如有其它疑问请加QQ(中国的一款聊天软件),QQ号码是1052165833。
I also encountered this problem, but I quickly resolved. I know what causes it, is because your computer to install the Microsoft.net Framework 3.0 (or. Net Framework 3.5) function of these managed encounter problems or errors caused by NGEN install fail, so long as you reinstall the installation . net Framework 3.5 SP1 can solve the general problem of change. If the problem still not resolved, you can uninstall it. Net Framework 3.0 installation after another. Net Framework 2.0 or t.net Framework 4.0 will solve the problem change. Hope this answer can help to you, plus any other questions please QQ (a chat software in China), QQ number is 1052165833.
下载Microsoft .NET Framework 2.0地址是:http://www.microsoft.com/downloads/zh-cn/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5
下载Microsoft .NET Framework 3.0地址是:http://www.microsoft.com/downloads/zh-cn/details.aspx?FamilyID=10cc340b-f857-4a14-83f5-25634c3bf043
下载Microsoft .NET Framework 4.0地址是:http://www.microsoft.com/downloads/zh-cn/details.aspx?FamilyID=0a391abd-25c1-4fc0-919f-b21f31ab88b7(内含64位操作系统的Microsoft .NET Framework 4.0)
安装Microsoft.net Framework可能要用到”Windows Installer 4.5 Redistributable“这个功能软件,下载地址是:http://www.microsoft.com/downloads/zh-cn/details.aspx?FamilyID=5a58b56f-60b6-4412-95b9-54d056d6f9f4
机器翻译的英文:
Download Microsoft. NET Framework 2.0 address is: http://www.microsoft.com/downloads/zh-cn/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5
Download Microsoft. NET Framework 3.0 address : http://www.microsoft.com/downloads/zh-cn/details.aspx?FamilyID=10cc340b-f857-4a14-83f5-25634c3bf043
Download Microsoft. NET Framework 4.0 address is: http://www.microsoft. com / downloads / zh-cn / details.aspx? FamilyID = 0a391abd-25c1-4fc0-919f-b21f31ab88b7 (Microsoft. NET Framework 4.0 for 64-bit operating system of in it)
Install Microsoft.net Framework may be used to " Windows Installer 4.5 Redistributable " this function software,download address is: http://www.microsoft.com/downloads/zh-cn/details.aspx?FamilyID=5a58b56f-60b6-4412-95b9-54d056d6f9f4
