well a NPT 1/2 hole gives me .721 [18.323 mm]
while an ISO Rc 1/2 comes in at .733 [18.613 mm]
Pipes are measured by nominal, 1/2inch in your case, bore of the pipe from the thred.xls
Eternal thread for 1/2 NB Pipe
G 1/2 | 1/2x14 BSP | G 1/2x14 BSP | 14 | A | 20.955 | 20.671 | 19.793 | 19.651 | 18.631 | |
G 1/2 | 1/2x14 BSP | 14 | B | 20.955 | 20.671 | 19.793 | 19.509 | 18.631 |
Internal thread for 1/2 NB Pipe
A | 18.631 | 19.172 | 19.793 | 19.935 | 20.955 | 19 | |
B |
So the dimensions you have give in your post are corect.
From a hand/pocket book that I have "Zeus Precision"
The nearest BSP size to 12.7mm tape hole is for a 1/4 Pipe (actually 11.8mm recommended, 11.75 Alternative for tapping and 17/32 for clearance)
As for the recommended Tapping drill for 1/2 Pipe
BSI Recommended 3/4in Dec 0.75
BSI Alternative 19mm Dec. 0.7480
Clearance 53/64 Dec 0.8281
I have also checked these against the BSP in thread.xls, I have some additional thread types added to the one that come with Inventor, the seizes as give above are CORRECT in the thread.xls file.
A 9/16 BSF thread M14 thread are the ONLY two that I can find in the thread.xls file that require at tap drill diameter of 12.7mm
Conclusion is that there is defiantly something wrong with what you have in you part thread/hole callout in you IDW file and it's not bad data it the actual part it's self that's wrong.
It may be better if you can post the IPT file and the IDW file so that we can have a better look at them and give us a better induction as to where it is wrong.
I hope that this might help explain things as to how inventor come up with the dimensions for a BSP threaded hole
I would like to add 3'' BSP Pipe Threads at thread.xls
which data is recommended?
