Announcements
Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
Whence (Mac) transparency (and others)?
1 REPLY 1
daguren
858 Views, 1 Reply
Learning Mac Inventor Fusion 2013. I can't find yet commands (menu or command line) to modify the transparency/opacity of a body/surface/edge (besides the quite dull and unuseful "glass" material).
Are there plans to provide IF access to the more extensive AutoCAD materials library?
Similarly, I can't find a way to display/edit (manually) an object's position or dimensions relative to (a select) origin.
I'm enjoying the product! Many thanks.
1 REPLY 1
SallyYang
in reply to: daguren
Thanks for your feedbacks. It's very helpful to hear the voice from customer and make our functionality more reasonable.
About transparency and material requirement, we have adopted it in future releases.
And for position and dimension issue, we will consider as an improvement for them.
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
