I want to draw a line using Δx and Δy not angle and distance?
By default you can enter a distance and an angle when you draw your next line in a sketch.
Is there any way to define the next line using difference in x and difference in y ?
I would of thought you should be able to right click and switch to Δx,Δy
Surely there's a way ??
Solved by SallyYang. Go to Solution.
Hi Franc,
Thanks for using our product. We are sorry to tell you that Fusion cannot support this behavior currently, and we will consider it as an improvement in future releases.
