Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
Value Entry Field doesn't show up when using Point command
1 REPLY 1
411 Views, 1 Reply
I am trying to learn Fusion but have hit some frustrating stumbling blocks. When I try to draw points on my sketch (to later join together to form a shape) there is no way to precisely locate them on the plane. The manual states that you can either place the pints directly on the plane or precisely enter the location in the value entry fields. These fields don't show up for me when drawing points. I do, however see the value entry fields when I am drawing lines. What gives???
1 REPLY 1
ChrisPan01
Thank you for the feedback!
Yes, currently, fusion does not suport enting points by coordinate. We are tracking it now.
A workaround is: You could create a point and then add sketch dimension. Edit the sketch dimension to get your wanted position.
Hope it helps.
-Chris
