Inventor Fusion
Inventor Fusion
New Member
jneang
Message 1 of 14 (345 Views)
Unable to shade or apply visual materials
345 Views, 13 Replies
12-11-2013 12:09 PM
One day using fusion 2013 on osx (9). I am unable to get my drawing to shade. no matter what i do under options > material (physical or material). It will only show the wireframe. Attached screenshot. How do I get this back so I can add color / shades to make it a solid?
Board Manager
Phil.E
Message 2 of 14 (281 Views)
Re: Unable to shade or apply visual materials
01-31-2014 08:39 AM in reply to: jneang
You need to set the view style to one that is Shaded.
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
Active Member
Tommo730
Message 3 of 14 (123 Views)
07-06-2014 01:25 PM in reply to: Phil.E
I have dowloaded Fusion for Mac today but I also have this problem. No matter which visual style I select it will not change from wireframe. If I select 'Realisic' the model dissapears altogether until another visual style is selected. I have even tried adding different materials etc to try and get the effect to work. I have also uninstalled and re-installed the software. Am I missing something more obvious or is there a problem?
Cheers, Tom
Board Manager
Phil.E
Message 4 of 14 (115 Views)
07-07-2014 08:20 AM in reply to: Tommo730
Apparently your material library is not installed or is corrupt.
  • You should be on OSX 10.7.5 or greater.
  • Uninstall
  •         Clearing your cache files
                 1. ~/Library/Application Support/Autodesk
                 2. $TMPDIR\Autodesk\BrowserCache
  • Try again.
Or better yet, install Fusion 360. This is the latest version of Fusion and is greatly improved over Inventor Fusion for Mac.
Phil Eichmiller
Active Member
Tommo730
Message 5 of 14 (110 Views)
07-07-2014 10:52 AM in reply to: Phil.E
Thank you very much, I shall try Fusion 360 :smileyhappy:
Active Member
Tommo730
Message 6 of 14 (76 Views)
07-14-2014 04:19 PM in reply to: Tommo730
Ok I having tried Fusion 360 its not quite what I am looking for.
I have tried removing and re-installing Inventor Fusion for Mac however I still have the same issue. It will not viualise any surface, colour or material. It only shows Wireframe, even if you attempt to change the visualisation options. If you try to shade without lines, or select realistic, the model dissapears completely.
Any help would be greatly appreciated, I am struggling to find a powerful 3d Cad program for Mac
Board Manager
Phil.E
Message 7 of 14 (71 Views)
07-14-2014 04:29 PM in reply to: Tommo730
If you are on a MacBook you should ensure that your energy saver settings are allowing use of the video card while on battery. That setting is Higher Performance.
Just curious, was there anything in particular about Fusion 360 you didn't like?
Phil Eichmiller
Active Member
Tommo730
Message 8 of 14 (67 Views)
07-14-2014 04:42 PM in reply to: Phil.E
Thanks for your reply, I've checked the settings in the Energy Saver section of the System Preferances, but there is nothing there to check whether the video card is activated - Ive never had any other issues and the laptop is rarely run on battery power alone.
With regards to Fusion 360,there's nothing about it I didnt like as such, its just I prefer to use a standalone peice of design software, there are more functions than I would probably ever use.
After watching the videos of Inventor Fusion in action I'd love to get to use it fully but at the moment I'm stuggling with this frustrating issue.
Cheers,
Tom
Active Member
Tommo730
Message 9 of 14 (65 Views)
07-14-2014 04:45 PM in reply to: Tommo730
Also, you may be able to see here, that if you have the model selected, the 2 material buttons seem to be inactive - if you go in the materials menu and select a material or colour it has no effect.
Board Manager
Phil.E
Message 10 of 14 (58 Views)
07-15-2014 08:04 AM in reply to: Tommo730
Do you by chance have AutoCAD or any other Autodesk products installed on this machine?
Phil Eichmiller
