Inventor Fusion
Member
neatgadgets
Message 1 of 5 (593 Views)
Sweep not working to create cylinder
593 Views, 4 Replies
12-28-2012 05:20 PM
I created a circle and a path coming from the center (sorry for the lack of terminology). I wanted to use sweep to form a cylinder around the path with the circle being the diameter of the cylinder. However it won't light up the tick to accept it. I am not sure what I am doing wrong.
JDMather
Message 2 of 5 (577 Views)
Re: Sweep not working to create cylinder
12-31-2012 09:42 AM in reply to: neatgadgets
The circle is on same plane as the path.
It should be on a plane perpendicular to the path.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
neatgadgets
Message 3 of 5 (572 Views)
12-31-2012 03:30 PM in reply to: JDMather
Thankyou for your reply. Happy New Years to you as well.
I though I had it perpendicular to the path. How do I get it perpendicular to the path?
Employee
Mike.Zhang
Message 4 of 5 (541 Views)
01-17-2013 10:43 PM in reply to: neatgadgets
I notice you only have one Sketch in your file, you need add 2nd Sketch which vertical the 1st sketch.
How to?
1.Toggle on the lamp before the Origin
2.Click the vertical workplane
3.Select New Sketch
4.Draw a line you want
5.Invoke Sweep command
6.First select your 1st profile
7.Then click the new line
8.OK.
Mike.Zhang
SQA Engineer
Fusion 360 Quality Assurance Team
Member
neatgadgets
Message 5 of 5 (350 Views)
05-19-2013 02:18 PM in reply to: neatgadgets
Thankyou for your reply, sorry for the delay, I have only just gotten back into Inventor.
