The problem is that i keep on trying to change the display to shaded but it doesn't change, before when i used to make a cube it used to be a grey 3-d shape but now this is what I get. Even the visual and physical materials cant be changed
Have you checked for new video drivers?
I am having the same issue. My drivers are all up to date, since i am using a mac (driver updates come with system updates). Any idea how to fix this?
On Mac, are you in power saver mode or using a VM?
no, I am not on power saver or using a VM. I am running everything normally. I even tried resetting the computer, updating all drivers, etc.
Sorry, but a couple more questions:
What is your graphics card?
Mac model and OS:
Thanks for your information! I need a little more:
What language/locale is your OS set on?
Thanks for bringing up the issue, Now we have logged defect UP-5832 to track the issue.
BTW, I also met the issue one time, it is just because that i don't install the complete material library. So you can have a try to see whether can solve the issue. Thanks.
