Hi. I have a model that looks great in IF, but when I export it to .stl both shapeways and imaterialise say it's unprintable because of file errors.
A helpful person at shapeways says it has "inverted normals" which I can see in netfabb basic.
But I don't know what she's talking about.
What are "normals" and how can I fix them?
I'll attach the IF file. (System won't let me attach .stl file. That might tell me something right there.)
Thanks!
David
Solved by qbqdavid. Go to Solution.
David,
I opened your model in Fusion 360 and found two solid bodies and one surface body. The surface body is just a cylinder shape. See the attached image, is that what you expect to find?
None of the faces show reversed normals. In Fusion 360 (and Inventor Fusion for Mac) you can see the "reverse" side as a golden colored face. See attached image. Using Surface/Patch tools, you can click on these surfaces and use a command called Reverse Normal to flip them, however I don't see any problem with your model.
You can try it yourself, get Fusion 360 here.
http://fusion360.autodesk.com/about
Hi Phil,
Thanks for the reply. The problem is, that surface body should not be in there. It's not in my model, nor apparent in the output files I have.
FYI, at the direction of the folks at Shapeways, I was able to remove the extra elements using Netfabb and everything printed fine.
Thanks!
David
Actually, the body is in your file. The visibility has been turned off for some reason.
See the images below, they show how to find and delete the problem surface body in your model.
