Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
Save dwg as 'Wireframe with Visible Edges Only'
2 REPLIES 2
ttfisker
1176 Views, 2 Replies
In Inventor Fusion under View -> Visual Styles, you can change the view to 'Wireframe with Visible Edges Only'.
How do I save the object in this view mode as dwg?
If I just save it as *.dwg it will be meshed once opened in Autocad LT and apart from Autocad there is no 'Visual styles' in Autocad LT.
See enclosed example
2 REPLIES 2
Phil.E
in reply to: ttfisker
The visual style is set by the program. The model is always the model, and the visual setting is how the software displays the model for you. If you only see mesh in AutoCAD LT it is due to limitations in AutoCAD LT, not because of the way Fusion is saving the model file.
Looking at the comparrison page between AutoCAD LT and regular AutoCAD it shows that LT does not support 3D.
http://www.autodesk.com/products/autodesk-autocad-lt/compare/compare-products
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
ttfisker
in reply to: Phil.E
I know of the FLATSHOT command in Autocad and also the visual styles supported by the 3D 'module' in Autocad.
Also, like you say, the Inventor Fusion View is a certain rendering of the model object but I hoped there would be some sort of workaround.
How about other software then? Do you know if it's possible to do 'FLATSHOT'-like (mesh removing) functions in other (preferably free) software.
