Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Reverse Engineering of an Centrifugal Pump Impeller Walkthrough
Dear Sirs,
We are studying to buy the Ultimate Suite that includes Inventor, Fusion 360 and other software, but we have a couple of weeks struggling to find a walkthrough for converting a scanned point cloud into a parametric solid. Specifically we are planning to buy a DAVID SLS-2 scanner that exports .obj or .stl point clouds. We are going to scan complex Water Pump Impellers and we need to find a way to build a parametric solid starting with the scanned data.
We have been in touch with the autodesk local representatives, but they don´t have any experience with our problem (Reverse engineering of scanned data). We have watched a bunch of youtube videos but we have been unable to find a solution within Autodesk software.
Please help us finding a solution to our requirement. (Scan the Object -> Proces the point cloud -> extract parametric surfaces and splines -> build the solid)
Thanks for your help!
Eng. David Valladares
Design and Engineering Chief
Global Motor, S. A.
[email protected]
+57 1 743 4500 Ext 222
Bogota, Colombia
Braxton08
Dear David
ReverseEngineering.com  supports your requirements with thier certified 2017 partner  add-in
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=22005804
Best Regards,
Braxton Carter |
HighRES, Inc / ReverseEngineering.com | 2746 Fay Ave Suite #200 (Merrill Lynch Bldg.) | La Jolla | CA | 92038 | USA
Phone: +1-858-488-5231 | Cell: +1-858-775-0571 | Fax: +1-858-459-5241
