Inventor Fusion
Member
NassimJ
Message 1 of 3 (379 Views)
Put a cylinder in a hole
379 Views, 2 Replies
01-02-2013 12:43 AM
I've just started with Inventor Fusion 2013 and I'm stuck with basic things.
I want to put a tube inside a box.
I drilled inside the box a hole at the same diameter as the extern diameter of the tube.
I tried to assembly them with " Assembly" tool but I didn't succeed in it. Either way, nothing happen or the button OK appears unclickeable.
If someone can show me how to solve that or a tutorial (I searched and I didn't find something)
Thank you in advance
Nassim
JDMather
Message 2 of 3 (373 Views)
Re: Put a cylinder in a hole
01-02-2013 04:13 AM in reply to: NassimJ
check if there is any information here that will help
http://au.autodesk.com/?nd=classes&filter_keywords=&chunk=15&filter_material=&filter_personal=&filte...
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Employee
Mike.Zhang
Message 3 of 3 (333 Views)
01-17-2013 10:55 PM in reply to: NassimJ
I open your file, just find only root component in it.
In Fusion, if you want to assemble two parts, you need to create them as two components before assemble.
There's a choice when you create a part, select the "New Component".
I also attached a model to show you the result.
Go ahead to try it!
Mike.Zhang
SQA Engineer
Fusion 360 Quality Assurance Team
