I've just started with Inventor Fusion 2013 and I'm stuck with basic things.
I want to put a tube inside a box.
I drilled inside the box a hole at the same diameter as the extern diameter of the tube.
I tried to assembly them with " Assembly" tool but I didn't succeed in it. Either way, nothing happen or the button OK appears unclickeable.
If someone can show me how to solve that or a tutorial (I searched and I didn't find something)
Thank you in advance
Nassim
Solved by Mike.Zhang. Go to Solution.
check if there is any information here that will help
I open your file, just find only root component in it.
In Fusion, if you want to assemble two parts, you need to create them as two components before assemble.
There's a choice when you create a part, select the "New Component".
I also attached a model to show you the result.
Go ahead to try it!
