Hi!
I'm doing a project for a ski, I've been able to make it in 3d, but right now I would like to solve a little problem:
You all know a ski, it has the tip and tail bend upwards, so if i draw an outlines for i.e. an 185cm long ski, when I'm going to press it (and bend it) I'll to loose some of that lenght, it will come out shorter than 185.
SO, my question is, since I've the 3D output of the 185 because I've drew it, pu**** up and then cut it with the side profile, can I have a profile of what the base outline from the 3D should be?
Hope that's clear enough.:)
Anyone?
I've seen only today that "pu**** up" I don't know why it come out like this, but it was a "push it up" aka extrude it
So what i need to do is a projection of a selected area from a curved solid, but it's not a classic projection: try to think at an orange, if I do a projection the lines are gonna be right were the orange is, what i need to do is something like peeling off the orange and lay it down.
