Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
[Problem] Inventor Fusion unable to open file created with Inventor Fusion
5 REPLIES 5
patyh
673 Views, 5 Replies
Hey Guys,
I created a model of a warehouse in inventor fusion for test in Simulation CFD. However, after saving the file and exiting inventor fusion, I was unable to open the file any more with inventor fusion crashing and requesting that I file an error report.
I've attached the problem file in this post to help in the troubleshooting of the issue.
5 REPLIES 5
Phil.E
in reply to: patyh
Thanks to Hugh Henderson! He rescued your file. See attached.
Phil Eichmiller
Software Engineer
Quality Assurance
patyh
in reply to: Phil.E
Hmm.. can't seem to find any file attached to your post.
Any solution to this problem yet?
Phil.E
in reply to: patyh
Attachment must have failed. Here you go.
Phil Eichmiller
Software Engineer
Quality Assurance
patyh
in reply to: Phil.E
Hey Phil,
Thanks for the help.. It seems though all the component names will be reset after recovering and will default to component (no.)
Is there a reason behind the failure in the first place and is autodesk planning a fix or is it expected to remain?
Phil.E
in reply to: patyh
I'm sorry, I didn't realize this was continuing to be a problem for you.
Can you provide the steps to repeat this problem?
What OS are you using?
Which version of Simulation CFD and Inventor Fusion are you using?
Thanks!
Phil Eichmiller
Software Engineer
Quality Assurance
