Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
Parallelogram mechanism
7 REPLIES 7
Message 1 of 8
MrNickBarker
2317 Views, 7 Replies
I'm trying to build a simple parallelogram mechanism which should lift a top plane.
My problem is that as soon as I add the last joint the model won't move and I get "Distance conflict due to joint type".
I'm guessing that it's mechally imposible for the joints to move the way they are setup, I've attached an image so you can see better.
Thanks in advance.
Tags (2)
7 REPLIES 7
Message 2 of 8
JDMather
in reply to: MrNickBarker
Can you attach the dwg file here?
Message 3 of 8
MrNickBarker
in reply to: JDMather
The file format which Inventor Fusion for Mac allows me to save is f3d and this forum doesn't allow f3d extensions for attachments, so I just replaced the extension with .dwg change to .f3d to open again.
I tried to use export but there isn't dwg there either.
Message 4 of 8
JDMather
I didn't realize you were using Mac version or that Mac version would not allow you to save dwg.
Message 5 of 8
MrNickBarker
It allows me to export to SAT, STL or STEP. When saving there is no option to choose type, it just saves it as f3d.
Message 6 of 8
Phil.E
Looking at your model I see a few problems. See attached image.
The joint origins are not lined up. This will cause the mechanism to bind. A mechanism like this requires the same joint origin spacing on both parts that the link bars are linking.
Please mark this response as "Accept as Solution" if it answers your question
Phil Eichmiller
Software Engineer
Quality Assurance
Message 7 of 8
MrNickBarker
in reply to: Phil.E
Thanks, thats what I figured.
Is there an easy way to align joint origins or to snap them toghether? A link to a tutorial would be apreciated (I've watched the esentials videos).
Message 8 of 8
Phil.E
Use [sketch>circle>extrude cut] to accurately locate holes. Use the holes for Joint Origins. Or use other geometry such as edges or corners that the Joint Origin command wants to snap to.
Phil Eichmiller
Software Engineer
Quality Assurance
