Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
Oval offset not working?
3 REPLIES 3
mixnmatch
1643 Views, 3 Replies
I'm fairly new to Inventor Fusion, so maybe I'm just not doing this correctly, but sketch oval offsets don't seem to be working in build 576.1.0 of Inventor Fusion Technology for Mac. I can get ellipse offsets to work (with the nearest axis highlighting), but curve-equidistant offsets (i.e. 'oval offsets' as per the manual) don't seem available- with the 'offset' command active, I'm not able to click on any point of the elliptical curve that is not near an axis. Both the Wiki and manual indicate this should be possible.
Thanks!
3 REPLIES 3
JDMather
in reply to: mixnmatch
Does it work in Fusion 360?
http://labs.blogs.com/its_alive_in_the_lab/2013/03/inventor-fusion-technology-preview-graduates-to-a...
mixnmatch
in reply to: JDMather
Yes, it does work in Fusion 360! Though I've noticed Fusion 360 does this odd 'pinching' of an inset oval (just on one side of the major axis), once you approach the inset limit.
Tags (2)
CAD-One
rmb enable loop select & then try offset. it should work.
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
