Inventor Fusion
Active Member
mixnmatch
Message 1 of 4 (998 Views)
Oval offset not working?
998 Views, 3 Replies
03-30-2013 10:31 PM
I'm fairly new to Inventor Fusion, so maybe I'm just not doing this correctly, but sketch oval offsets don't seem to be working in build 576.1.0 of Inventor Fusion Technology for Mac. I can get ellipse offsets to work (with the nearest axis highlighting), but curve-equidistant offsets (i.e. 'oval offsets' as per the manual) don't seem available- with the 'offset' command active, I'm not able to click on any point of the elliptical curve that is not near an axis. Both the Wiki and manual indicate this should be possible.
Thanks!
JDMather
Message 2 of 4 (982 Views)
Re: Oval offset not working?
04-01-2013 06:27 AM in reply to: mixnmatch
Does it work in Fusion 360?
http://labs.blogs.com/its_alive_in_the_lab/2013/03/inventor-fusion-technology-preview-graduates-to-a...
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Member
mixnmatch
Message 3 of 4 (965 Views)
04-02-2013 06:33 AM in reply to: JDMather
Yes, it does work in Fusion 360! Though I've noticed Fusion 360 does this odd 'pinching' of an inset oval (just on one side of the major axis), once you approach the inset limit.
CAD-One
Message 4 of 4 (639 Views)
05-06-2014 07:43 AM in reply to: mixnmatch
rmb enable loop select & then try offset. it should work.
C1
Vault Professional 2015
