Inventor Fusion
Inventor Fusion
Active Member
1 Kudo
Post 1 of 5
New Macbook Pro Retina compatibility? Random beachballs of death...
715 Views, 4 Replies
09-05-2012 11:36 PM
I am trying to use Inventor Fusion for Mac to create some simple parts and I get the spinning beach ball of death at random times into working with the part.  Simple sketches only, just lines and circles.   I get 30 minutes or so in to recreating the part and then I get the beachball, then the Autodesk error reporting window... then I have to start over again.
I am using OS X 10.8.1 on a 2.7GHz Intel Core i7, 16mb of ram, 768Gb SSD (all stock Apple).  I am also driving a 30" external Apple Cinema display but the problems also occur if I do not use the external display.  I am doing this while all other software is off (except for Dropbox but the file I am creating is not in a Dropbox folder). I can work around using a mac mini I have which has not given me the problem so far but I would sure like to use my more powerful machine and not have to change my desk setup to use Inventor Fusion.
I like Inventor Fusion a lot I assume it is trial software for a more featured mac program for sale in the future?  Thanks for any hints or tips!
2 Kudos
Post 2 of 5
Re: New Macbook Pro Retina compatibility? Random beachballs of death...
09-09-2012 12:56 PM in reply to: dbgerull
As seen here and their App Store reviews, a bunch of us with Retina MBP's seem to be having similar problems. I went a half hour this time before crashing and ending up with a corrupted file :smileysad: A new record!
I hope they fix this soon.
Employee
10 Kudos
Post 3 of 5
09-10-2012 03:15 AM in reply to: bentwookie
Thanks your information.
We will analyze this issue, and try to fix it in next version.
Mike.Zhang
SQA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Active Member
1 Kudo
Post 4 of 5
09-10-2012 04:28 PM in reply to: dbgerull
Thanks.  If I had to guess as to what the problem was it seems like  it occurs mostly when commands don't process quickly and get queued up and the software gets confused trying to process them in sequence.
I am a (very) new user and basic stuff such as selecting an edge and then using orbit to move around and select another edge can cause problems.  The instruction materials don't explain very basic interface guidelines such as how to select, orbit, select again so I end up trying left/right/center clicks and notice the infamous beachball most often shows up after such random clicking.  After selecting an edge and then picking orbit, I guess that middle (scroll wheel) should get me out of orbit and back into the select but I am guessing and so may end up with a few extra clicks that then leads to a beachball.
I try to save the file and rename the current workspace to something new before trying anything that takes time as the problem is particularly nasty when it not only crashes but also corrupts the file.
On a related note, Pre-loading the "Save As" field with the current filename would help as well as then I could save versions quickly (as 1, 2, 3, etc.).  Right now the field is blank so saving backup files in case of crash/corruption also takes a lot of typing.
Cheers.  Still a good program for the price. :smileyhappy:
Employee
10 Kudos
Post 5 of 5
03-05-2013 07:01 PM in reply to: dbgerull
This issue should be fixed now.
Could you try it on the latest build?
You can install it from below link:
http://adsk-streamingdeploy-beta.elasticbeanstalk.com/install/app/73e72ada57b7480280f7a6f4a289729f/
Mike.Zhang
SQA Engineer
Autodesk, Inc.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
