Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
Showing results forĀ
Did you mean:Ā
Need Help Converting Mesh into Solid/Surface
1 REPLY 1
737 Views, 1 Reply
I have a model in Autodesk Inventor Fusion 2013 that was imported from Google Sketchup. The model says that it is only a mesh. How can i convert the model into either a solid, or a series of solid faces?? Any help in much appreciated!
1 REPLY 1
Phil.E
There likely isn't a way to convert it. Fusion allows such import for reference purposes.
Is there some way to get the same file exported from Sketchup as another file type, or with some option that doesn't produce only  a mesh?
Phil Eichmiller
Software Engineer
Quality Assurance
