Inventor Fusion
Distinguished Contributor
cristiano.oliveira
Message 1 of 4 (396 Views)
Multiples commands on Menu File
396 Views, 3 Replies
11-05-2009 04:31 AM
After installed the Fusion Preview 2 and Manager, in Inventor 2010 Pro with SP1.
When IPT files is open, appear multiples commands "Open DWG" in my Menu File.
Follow attach.
Cristiano Oliveira
Autodesk Certified
http://managermachine.blogspot.com
Employee
Huan.Yu_Autodesk
Message 2 of 4 (396 Views)
Re: Multiples commands on Menu File
11-23-2009 11:41 PM in reply to: cristiano.oliveira
Thanks for the feedback.We have reported this problem to our development and it is on track.
The problem occurs under Inventor Clissic UI and it is OK under Ribbon UI.You can work around it by changing Inventor UI to Ribbon UI and back to classic UI.
-Huan
Employee
Huan.Yu_Autodesk
Message 3 of 4 (396 Views)
11-24-2009 07:14 PM in reply to: cristiano.oliveira
More info:
You may delete the PartFileMenu folder in Windows Registry editor here to get rid of the multiples commands "Open DWG" in Classic UI: HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion14.0\UI Customization V5\ToolBars\PartFileMenu
It is also suggested to use Change Manager in Ribbon UI before the problem is resolved.
-Huan
cristiano.oliveira
Message 4 of 4 (396 Views)
11-25-2009 02:39 AM in reply to: cristiano.oliveira
Thank You Huan. I change the UI. Now is correct.
Cristiano Oliveira
Autodesk Certified
