Inventor Fusion
Inventor Fusion
Active Member
0 Kudos
Post 1 of 4
Making assembled pieces move together
677 Views, 3 Replies
12-11-2012 10:32 PM
Would someone be able to summarize briefly how bodies/components are ordered in Fusion so that they move/animate as expected?
I've put together a two-solenoid motor that animates as expected with one solenoid. However when assembling the opposing solenoid, I've not been successful. As soon as I get the connecting rod attached to the crank, it breaks with "Selected joint type will result in conflict", "Angle conflict due to joint type", and "Distance conflict due to joint type", although it's basically the same as the other side.
Now, I just decided to see if the opposing solenoid can function on its own, with the other solenoid disconnected and it fails. Both plunger and hub/crank can move independently, but, when connected, fails. I'd like to understand what's going on.
The opposing solenoid is made up of mirrored non-moving parts and copied/pasted moving parts (plunger, connecting rods and linkage). Something is wrong with my understanding of body/component placement in the browser and the way I've set it up. Or, perhaps, Fusion, at this stage, just can't comprehend movement of opposing/mirrored parts.
Any ideas?
Solenoid motor file
Active Member
0 Kudos
Post 2 of 4
Re: Making assembled pieces move together
12-22-2012 05:33 PM in reply to: digital_dreamer
Success!
I've finally completed this little project.
The secret to getting interdependent moving parts working is to ensure all parts are properly aligned prior to assembly. You can't expect Fusion to resolve all joint issues at once. This can be rather tricky and may take a number of different paths. I had to slide the solenoid cylinder out away from the plunger first, so Fusion could resolve those joint conflicts first. Let Fusion align the parts, then move cylinder back into position.
I think having more than one part out of alignment at once can throw Fusion into conFusion. :smileywink:
MAJ
New Member
0 Kudos
Post 3 of 4
01-04-2013 09:56 AM in reply to: digital_dreamer
Which t-slot system is that you are using?   (the aluminum bars with the slots in them).... that one looks different than the ones I have been looking at.
Active Member
0 Kudos
Post 4 of 4
01-04-2013 10:41 AM in reply to: xtofury
They are just the 25 series (Metric) of the 80/20 t-slots.
CAD models are available, too.
best of wishes,
MAJ
