Helloo,
Im faceing the problem in Inventor fussion 2012 which is crashing at the start up.
and i have attached error report.
i have check all the below steps.
1.) Checked the Inventor fusion without Anti-virus.
2.) We have installed Windows 7 Professional SP1.
3.) Tried in with Administrator credentials.
4.) Checked the Inventor fusion after UAC turned off.
5.) Checked the Inventor fusion in 'True Color' adapter mode.
6.) We have removed Cascade info file from C:\ProgramData\Autodesk\AdLM
7.) We have reconfigured the Autodesk Inventor fusion 2012 profile from C:\Users(username)\AppData\Roaming\Autodesk (both in Roming and Local)
8.) Updated Service Packs.
9.) 3rd Parties reinstalled(.net, microsoft c++, Direct x).
10.) Finally clean uninstall & Reinstalled.
Please suggest some solutions.
How is your video card? Are the drivers up to date and is it a supported video card?
Hello Phil Eichmiller,
All the drivers are upto date, and i have checked in Autodesk Certified Hardware too.
Madhu.S
Madhu,
Welcome to the forum.
According to the XML file the you up loaded your video graphics was published in 2010.
I would like you to install the following driver for you Nvidia Quadro 2000:
http://www.nvidia.com/download/driverResults.aspx/72759/en-us
Please get back to us with your results.
Thank you.
