Announcements
Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
cholte
666 Views, 3 Replies
Inventor Fusion
Why can’t Inventor Fusion save an imported STP file as a Inventor part?
3 REPLIES 3
TravisNave
in reply to: cholte
This is an installation and network licensing forum.  Please post this in the appropriate Inventor forum for better results.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
ampster402
in reply to: TravisNave
I don't normally browse this forum, but isn't this where you would post question about Inventor Fusion?
There is a separate Installation and Licensing forum here;
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Hi,Cholte,
Many thanks for bringing up the issue. Are you using Inventor Fusion 2013? Officially, Inventor Fusion 2013 supports to export file to like DWG, SAT and other file formats,  not support to export to ipt file. But Fusion has the integration workflow with Inventor.So user can edit Inventor files in Fusion, then back to Inventor to continue editting.
Hope this helps.
Wendy
Wendy Chen
Fusion 360 Team
Autodesk, Inc.
