Inventor Fusion
cholte
Message 1 of 4 (344 Views)
Inventor Fusion
344 Views, 3 Replies
06-04-2012 12:56 PM
Why can’t Inventor Fusion save an imported STP file as a Inventor part?
TravisNave
Message 2 of 4 (341 Views)
Re: Inventor Fusion
06-04-2012 01:19 PM in reply to: cholte
This is an installation and network licensing forum.  Please post this in the appropriate Inventor forum for better results.
*Pro
ampster
Message 3 of 4 (314 Views)
Re: Inventor Fusion
06-06-2012 12:30 PM in reply to: TravisNave
I don't normally browse this forum, but isn't this where you would post question about Inventor Fusion?
There is a separate Installation and Licensing forum here;
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Employee
Wendy.Chen_Autodesk
Message 4 of 4 (302 Views)
Re: Inventor Fusion
06-06-2012 08:00 PM in reply to: cholte
Hi,Cholte,
Many thanks for bringing up the issue. Are you using Inventor Fusion 2013? Officially, Inventor Fusion 2013 supports to export file to like DWG, SAT and other file formats,  not support to export to ipt file. But Fusion has the integration workflow with Inventor.So user can edit Inventor files in Fusion, then back to Inventor to continue editting.
Hope this helps.
Wendy
Wendy Chen
Fusion 360 Team
