Inventor Fusion
Active Contributor
jameslenane
Message 1 of 23 (1,201 Views)
Inventor-fusion
1201 Views, 22 Replies
12-29-2011 09:09 AM
when im using inventor i cant click on fusion in the applications options,eventhough it says recommended,it just stays greyed out,anybody have a solution to this?Id really appreciate some feedback as posted this before but didnt get any answers so im at a loss to the reasons for this!
Board Manager
schneik
Message 2 of 23 (1,182 Views)
Re: Inventor-fusion
01-02-2012 12:53 PM in reply to: jameslenane
Can you confirm that Inventor Fusion 2012 is installed? Can ou run it from the shortcut in the Start -> Program group?
Kevin Schneider
15" Macbook Pro Retina - OSX 10.9 in Portland, Oregon
Active Contributor
jameslenane
Message 3 of 23 (1,175 Views)
Re: Inventor-fusion
01-03-2012 08:09 AM in reply to: jameslenane
Thanks for the reply and i can open fusion from the start menu,programs so i dont know why i cant from app options and it doesnt open as the model only as an autocad drawing?
James
Board Manager
schneik
Message 4 of 23 (1,154 Views)
Re: Inventor-fusion
01-05-2012 08:42 PM in reply to: jameslenane
When you open a Fusion DWF in Inventor. On the open dialog, in Inventor, select options. Select import and then open the DWG. This should launch the DWG import dialog and recognize the file as a Fusion DWG.
Kevin Schneider
Active Contributor
jameslenane
Message 5 of 23 (1,145 Views)
Re: Inventor-fusion
01-06-2012 07:25 AM in reply to: jameslenane
Hi Kevin
Thanks for your help but i seem to be getting nowhere fast,if i open inventor I cant even find fusion files,I can only find fusion files if fusion is open,to be honest the fileing system seems to be not the easiest to work your way around and im getting so frustrated,I even uninstalled fusion last night and reinstalled it to see if it would show up in the applications menu but no joy,Im at a loss and without having somebody beside me to have a look or tell me if im doing something wrong I dont know what to do,its my studies im worried about,is there any other free form modeling programe I can run with inventor,I still think it must be something im doing wrong?
James lenane
Active Contributor
jameslenane
Message 6 of 23 (1,144 Views)
Re: Inventor-fusion
01-06-2012 07:29 AM in reply to: jameslenane
Sorry Kevin I meant to say I cant open fusion files from inventor as they dont show up anywhere even in the dialog box,the options icon stays greyed out and you cant pick it!
James lenane
Board Manager
schneik
Message 7 of 23 (1,138 Views)
Re: Inventor-fusion
01-06-2012 11:04 AM in reply to: jameslenane
OK.
Thanks for the patience. As we try to figure out what is going wrong.
First, can we do a simple test?
Start Fusion and create a box and save it to your desktop.
Open Inventor, and "Import" the Fusion .dwg file into Inventor. You will have to change the open file dialog to ".dwg" or "all inventor files" file type filter. Use the options button to make sure that you import not open.
The dwg import wizard should recognize its a fusion file.
A new ipt should be created with a base feature and the solid block visible in the graphics.
Now right mouse click on the face feature and select edit solid.
(this is where things seem to be messed up)
Does Fusion launch or does the old edit solid environment open up?
Kevin Schneider
Active Contributor
jameslenane
Message 8 of 23 (1,133 Views)
Re: Inventor-fusion
01-06-2012 05:42 PM in reply to: jameslenane
kevin it didnt work,i got to the stage that you asked me too eventually but i had to do a few things a little different to get there but it wont launch fusion,i was in the old edit solid environment and it opened a box in the graphics window saying"inventor fusion technology preview provides enhanced solid edit functionality,go to http://labs.autodesk.com/utilities/fusion/for more information1 you can click ok or prompts>>
James
Active Contributor
jameslenane
Message 9 of 23 (1,109 Views)
Re: Inventor-fusion
01-10-2012 01:27 PM in reply to: jameslenane
Kevin how are you?,fusion is driving me mad buddy,opened tonight to try and do some basic study work and it shut down 2 or 3 times saying the catalyst stopped working,driving me nuts,I cant learn something that keeps giving me problems as theres no continuity,my study plan has failed before it began.
James
Board Manager
schneik
Message 10 of 23 (1,077 Views)
Re: Inventor-fusion
01-15-2012 05:16 PM in reply to: jameslenane
That is not good. Do you know if you have SP3 installed. There seems to be something very odd with this install of Fusion. Where was it installed from? From a USB key containing AutoCAD or Inventor or was it downloaded from Labs?
Kevin Schneider
