Inventor Fusion
Inventor Fusion
New Member
charlene936
Message 11 of 59 (1,454 Views)
Re: inventor fusion mac crashes trying to open saved files
08-28-2012 11:19 AM in reply to: Wintaru
New Member
matthiastrav410
Message 12 of 59 (1,444 Views)
08-29-2012 01:49 PM in reply to: Wintaru
Active Member
dbgerull
Message 13 of 59 (1,424 Views)
09-02-2012 01:24 AM in reply to: tbabcock123
Have the same problem.  Making some relatively simple parts to try out 3D printing and after I put a few fillets around everything the two files I was working on give me the spinning beachball of death after saving and trying to restart later.
 Was very worried as I put some time into the parts (learning mostly) and thought everything may be gone as the problem is repeatable.  My work was being done on a 2.7Ghz i7 macbook pro 15" retina display with 16gb memory, 768Gb SSD and driving a 30" cinema display.  Luckily I have a mac mini with considerably less power/memory and it is able to open the files so I am not up the creek totally.
Any tips very appreciated, I would like to use my macbook as it is much more powerful than the mini but it just won't open the files it saves after a certain point.  Cheers.
Employee
Mike.Zhang
Message 14 of 59 (1,416 Views)
09-03-2012 12:34 AM in reply to: Wintaru
Thanks for sharing this file, we'll  analyze your model, then try to find the reasons.
Thanks again.
Mike.Zhang
SQA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
New Member
hugo.salinas
Message 15 of 59 (1,386 Views)
09-09-2012 10:07 PM in reply to: tbabcock123
Same problem here. I was working on a project, when i came back latter that day and reopend it i was unable to open it without inventer crashing. I have a MAC retina. I wont complain because it is free software and **** good software at that! no hate. but a fix would be awesome.
Member
saltsaint
Message 16 of 59 (1,347 Views)
09-30-2012 08:28 AM in reply to: tbabcock123
Great that you are searching for a solution to fix this.
Fact is that IF for Mac is unusable on my machine because of this crashes...
Active Member
cbrinke1
Message 17 of 59 (1,333 Views)
10-01-2012 06:47 AM in reply to: tbabcock123
I too am seeing consistent crashes (especially when opening a saved file). I am running Mountain Lion 10.8.2 on my 8GB MacBook Pro w/retina display. The crashes only occur when opening .f3d files. If I export the models to .step .stp or .sat files they open fine. Additionally if I try to open the .f3d file that _doesn't_ work on my retina laptop with my wifes Mac Mini (running Lion) it opens fine as well. I have submitted a fair amount of bugs through the always appearing crash dialog :smileyhappy:
  I have attached a quick model I created on my laptop that will crash Fusion every time I try to open it. I also have attached a .sat file that was exported from the original model (while I was creating it) that opens without issue but is missing dimension info. Since the forums webapp here won't allow them named as such, I have appended .txt to the file name.
Chris
Member
Sferril
Message 18 of 59 (1,249 Views)
10-22-2012 03:05 AM in reply to: tbabcock123
Fusion was saving and opening successfully on 10.7 Lion.  The first 5-10 files I made work fine, but anything I save now will not open again.  A lot of work simply lost if they can't be resurrected.  I'm on a mac 5,2.  Attached a new file that was saved but won't open again.
sf
Member
Sferril
Message 19 of 59 (1,245 Views)
10-22-2012 03:49 AM in reply to: Sferril
I moved to a newer desktop, same operating system (10.7.5) and downloaded the app.  It opened the file without a problem.  It is a MacPro Desktop 5,5.  I'll see if it eventually has the same issue.
Thanks, sf
New Member
horfee
Message 20 of 59 (1,242 Views)
10-22-2012 03:04 PM in reply to: tbabcock123
Same problem : with a very simple file (5 little box with joints), the software is crashing  when loading the file (the software freezes without giving up the control)
I could provide 3 files that make it crash.
I am running on a Mac Book Pro 2011, Mac OS X 10.8.2, 8Gb of RAM.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
