Inventor Fusion
Inventor Fusion
Board Manager
schneik
Message 31 of 59 (734 Views)
Re: inventor fusion mac crashes trying to open saved files
12-31-2012 06:51 PM in reply to: Sferril
We are still trying to find the source of the problem. Any details and f3d files (zipped) that you can post will help.
Kevin Schneider
13" Macbook Pro Retina - OSX 10.10.1 in Portland, Oregon
Active Member
net-marker
Message 32 of 59 (722 Views)
01-03-2013 06:45 AM in reply to: schneik
herby a file that let grash the application. I see forrward to a solution
marc.liyanage
Message 33 of 59 (713 Views)
01-03-2013 08:58 AM in reply to: schneik
The attached file crashes Inventor Fusion every time I try to open it.
New Member
craigdurrant6580
Message 34 of 59 (699 Views)
01-04-2013 03:07 PM in reply to: tbabcock123
Hi, Same problem. I try to open a file (attached) that I have spent days working on, multicoloured umbrella of death, then Fusion Error Report pops up. I then have to Force Quit the app. Other files open fine.
Nearly four months since this topic was brought up and no fix yet?
Has anybody found a work around to recover the file or is it a lost cause? Are there any other apps (autodesk or otherwise) that will open .f3d files?
Thanks.
2013 iMac, 2.7 Ghz, 8 Gb RAM.
Active Member
dbgerull
Message 35 of 59 (693 Views)
01-04-2013 03:23 PM in reply to: craigdurrant6580
I guess we get what we pay for :smileyhappy:
I have frequent crashes with the same relatively small part file across all three of my machines:
a) MacMini with 512gb SSD, 8gb memory
b) 15" MacBook Pro Retina with 768gb SSD, 16gb Memory, 2.7 GHz i7
c) 27" iMac with 3Tb drive, 32gb memory, i7
Sometimes the crashes feel truly random but if there is any consistency it seems I can "force" a kernel panic beach ball if I do not wait for commands to "take" such as selecting items and moving on to the next operation without pausing to see if the part highlights, etc. before moving on.
I hope they do track this down someday as I like the product but feel very reluctant to move on to any very complicated or designs that takes a larger investment of time as you just don't know when it will bite you.
Cheers!
Active Member
cbrinke1
Message 36 of 59 (691 Views)
01-04-2013 03:43 PM in reply to: schneik
The only work around I have found was to: Take the .f3d file and open it on a mac that is running Lion (previous OS version). Export the file to a .stp or .sat file. Then on the machine that has the issue, open a new file and import the .sat/.stp file you just generated and it should work without issue.
The downside to this approach is that .sat/.stp files are not as feature rich (I think you lose some detail), but at least you get access to your hard work while Autodesk figures out what is wrong.
 I spent a few weeks just working with .sat/.stp files, but eventually abandoned fusion because of this issue. I am now working in openscad until autodesk gets a fix.
Chris
New Member
craigdurrant6580
Message 37 of 59 (680 Views)
01-05-2013 09:09 AM in reply to: cbrinke1
Unfortunately i am a recent convert, and I don't know anybody that has an older Mac. Will anybody on here be able to export my file to .stp and post/email it back?
Thanks.
Active Member
cbrinke1
Message 38 of 59 (638 Views)
01-15-2013 06:07 PM in reply to: craigdurrant6580
The only work around I have found was to: Take the .f3d file and open it on a mac that is running Lion (previous OS version). Export the file to a .stp or .sat file. Then on the machine that has the issue, open a new file and import the .sat/.stp file you just generated and it should work without issue. The downside to this approach is that .sat/.stp files are not as feature rich (I think you lose some detail), but at least you get access to your hard work while Autodesk figures out what is wrong. I spent a few weeks just working with .sat/.stp files, but eventually abandoned fusion because of this issue. I am now working in openscad until autodesk gets a fix. Chris
New Member
rewheaton
Message 39 of 59 (616 Views)
01-23-2013 12:12 PM in reply to: tbabcock123
Experiencing the same problem.  Forum won't let me attached f3d files.
Moutain Lion
2.4 GHz Intel Core i7
8 GB 1333 MHz DDR3
AMD Radeon HD 6770M 1024 MB
OS X 10.8.2 (12C60)
Employee
SallyYang
Message 40 of 59 (556 Views)
02-06-2013 09:45 PM in reply to: rewheaton
We will fix the stability issues in later release, please pay attention to the update.
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
