Inventor Fusion
Inventor Fusion
Member
Sferril
Message 21 of 59 (1,014 Views)
Re: inventor fusion mac crashes trying to open saved files
10-24-2012 04:00 AM in reply to: Sferril
More to add... on the newer computer, fusion crashes often but I can open the file if I specifically open fusion, then use the "open" command.  The file pops up.  Not sure if this helps identify the problem.
sf
Active Member
net-marker
Message 22 of 59 (999 Views)
10-27-2012 05:57 AM in reply to: Sferril
Hallo Same problems here (mac IOS 10.8.2)
I was wondering if Autodesk can give an indication when this issue can be solved. Or are there maybe some tricks to open the file via another way? This because I like to continue on my work. I would like to keep doing this in Fusion rather then starting over again in another program.
Active Member
cbrinke1
Message 23 of 59 (994 Views)
10-27-2012 08:55 AM in reply to: tbabcock123
I have been working with one of the developers for the past few months. He confirmed to me in a recent email that the issue is based around Mutli Threading and seems to affect certain hardware/OS combinations, and that they are working on a fix:
"Yes, we have seen couple of MT issues while processing the graphics scenes(on particular hardware and OS combinations) while opening some files. And we are working on it now. So probably you will get this fix in our next release."
The only workaround I have found is to use Inventor on older Hardware or an earlier OS (Lion seems unaffected). It is less than ideal to lug around another MBP just for this, but it is cheaper than a commercial license for autodesk Fusion :smileywink:
Chris
Active Member
net-marker
Message 24 of 59 (987 Views)
10-28-2012 09:39 AM in reply to: Sferril
Hi Chris,
You say the best thing is to wait for the next update. Can you tell me to when this update will be released. Also I understand that the issue is based around Mutli Threading, will this mean that I can try to eliminate some other background programs that interference with each-other?
I hope i can continue working with Fusion soon because I really like the usability of this design program!
jorn
New Member
benoit.vanhoutte
Message 25 of 59 (944 Views)
11-06-2012 08:10 AM in reply to: tbabcock123
Gosh ...
Same issue !
Working during 3 hours on a file this morning. Saving it as .f3d (original setting ..)
Having a good lunch since i am happy of my morning job.
Then, opening it and ... crash.
Impossible to open my files.
Are you sure that you are going to solve this issue in a while ?
Does QA Autodesk is working on erro report automaticly sent ?
The BEST : Impossible to attach file with f3d extension to this post  !!!!!!!
Regards, Benoit
Active Member
net-marker
Message 26 of 59 (923 Views)
11-10-2012 12:56 PM in reply to: Sferril
Hello, It would be nice if somone can give feetback on the current solutin of the satus., when will there be update?
Board Manager
schneik
Message 27 of 59 (919 Views)
11-10-2012 06:06 PM in reply to: Sferril
can you zip the file and post it?
Kevin Schneider
13" Macbook Pro Retina - OSX 10.10.1 in Portland, Oregon
New Member
benoit.vanhoutte
Message 28 of 59 (813 Views)
11-30-2012 09:09 AM in reply to: schneik
hello
here is my file that crash the app.
Other issue is : impossible to import .DWG
Here in attachement the files concerned.
Thank you for your help
Benoit
Employee
Macro.Liu_Autodesk
Message 29 of 59 (733 Views)
12-26-2012 09:36 PM in reply to: benoit.vanhoutte
I download the .zip file but fail to unzip it and just copy the .f3d file out. So would you please attach the .f3d file directly or email it to LiangDOTLiu@autodeskDOTcom. I'll take a look then.
For the DWG open issue, please make sure there's 3D Solid/Surface data in DWG.
Macro Liu
New Member
typod123
Message 30 of 59 (718 Views)
12-27-2012 06:27 PM in reply to: Macro.Liu_Autodesk
I am having the same unexpected quits during simple extrusions.  I'm running Fusion on a 16GB 2.6Ghz MBP retina.  I had used fusion with very complex assemblies on an old 13 MBP with no issues.  With the new retina, I am able to perform one extrusion and once i begin a revolve command or extrude cut, the program will crash.  This happens whether I save or don't save the part and happens to all fietypes.
I checked to see if this was related to the retina's graphics switching or screen scaling, but changing either of these variables doesn't seem to affect the program stability.  I'm hopeful that an update is on the horizion.
