Inventor Fusion
Inventor Fusion
New Member
0 Kudos
Post 11 of 59
Re: inventor fusion mac crashes trying to open saved files
08-28-2012 11:19 AM in reply to: Wintaru
New Member
1 Kudo
Post 12 of 59
08-29-2012 01:49 PM in reply to: Wintaru
Active Member
1 Kudo
Post 13 of 59
09-02-2012 01:24 AM in reply to: tbabcock123
Have the same problem.  Making some relatively simple parts to try out 3D printing and after I put a few fillets around everything the two files I was working on give me the spinning beachball of death after saving and trying to restart later.
 Was very worried as I put some time into the parts (learning mostly) and thought everything may be gone as the problem is repeatable.  My work was being done on a 2.7Ghz i7 macbook pro 15" retina display with 16gb memory, 768Gb SSD and driving a 30" cinema display.  Luckily I have a mac mini with considerably less power/memory and it is able to open the files so I am not up the creek totally.
Any tips very appreciated, I would like to use my macbook as it is much more powerful than the mini but it just won't open the files it saves after a certain point.  Cheers.
Employee
10 Kudos
Post 14 of 59
09-03-2012 12:34 AM in reply to: Wintaru
Thanks for sharing this file, we'll  analyze your model, then try to find the reasons.
Thanks again.
Mike.Zhang
SQA Engineer
Fusion 360 Quality Assurance Team
New Member
0 Kudos
Post 15 of 59
09-09-2012 10:07 PM in reply to: tbabcock123
Same problem here. I was working on a project, when i came back latter that day and reopend it i was unable to open it without inventer crashing. I have a MAC retina. I wont complain because it is free software and **** good software at that! no hate. but a fix would be awesome.
Member
0 Kudos
Post 16 of 59
09-30-2012 08:28 AM in reply to: tbabcock123
Great that you are searching for a solution to fix this.
Fact is that IF for Mac is unusable on my machine because of this crashes...
Active Member
0 Kudos
Post 17 of 59
10-01-2012 06:47 AM in reply to: tbabcock123
I too am seeing consistent crashes (especially when opening a saved file). I am running Mountain Lion 10.8.2 on my 8GB MacBook Pro w/retina display. The crashes only occur when opening .f3d files. If I export the models to .step .stp or .sat files they open fine. Additionally if I try to open the .f3d file that _doesn't_ work on my retina laptop with my wifes Mac Mini (running Lion) it opens fine as well. I have submitted a fair amount of bugs through the always appearing crash dialog :smileyhappy:
  I have attached a quick model I created on my laptop that will crash Fusion every time I try to open it. I also have attached a .sat file that was exported from the original model (while I was creating it) that opens without issue but is missing dimension info. Since the forums webapp here won't allow them named as such, I have appended .txt to the file name.
Chris
Member
0 Kudos
Post 18 of 59
10-22-2012 03:05 AM in reply to: tbabcock123
Fusion was saving and opening successfully on 10.7 Lion.  The first 5-10 files I made work fine, but anything I save now will not open again.  A lot of work simply lost if they can't be resurrected.  I'm on a mac 5,2.  Attached a new file that was saved but won't open again.
sf
Member
0 Kudos
Post 19 of 59
10-22-2012 03:49 AM in reply to: Sferril
I moved to a newer desktop, same operating system (10.7.5) and downloaded the app.  It opened the file without a problem.  It is a MacPro Desktop 5,5.  I'll see if it eventually has the same issue.
Thanks, sf
New Member
0 Kudos
Post 20 of 59
10-22-2012 03:04 PM in reply to: tbabcock123
Same problem : with a very simple file (5 little box with joints), the software is crashing  when loading the file (the software freezes without giving up the control)
I could provide 3 files that make it crash.
I am running on a Mac Book Pro 2011, Mac OS X 10.8.2, 8Gb of RAM.
