Inventor Fusion
Inventor Fusion
New Member
tbabcock123
Message 1 of 55 (2,484 Views)
inventor fusion mac crashes trying to open saved files
2484 Views, 54 Replies
08-16-2012 10:01 AM
OS: 10.7.4
RAM: 16 GB ram
either double clicking the file or calling it from the 'recent files' panel will cause the 'rainbow wheel of death' and the application crashes - makes the application useless.
Apple App Store is updated with a "dot" release that fixes the file corruption issue.
Older files may not open but if you post here we can try some internal tools to recover data. We apologize for the trouble.
Employee
Macro.Liu_Autodesk
Message 2 of 55 (2,470 Views)
Re: inventor fusion mac crashes trying to open saved files
08-16-2012 07:23 PM in reply to: tbabcock123
Would you please share any simple data that can reproduce this issue with us? We'll do some investigation.
Macro Liu
Inventor Fusion QA Team
New Member
tbabcock123
Message 3 of 55 (2,465 Views)
08-16-2012 08:42 PM in reply to: Macro.Liu_Autodesk
i'm attaching an archive of two files, neither of which i can open (though they were created with my copy of inventor fusion).  they cause the program to crash.
New Member
EddieDraaisma
Message 4 of 55 (2,440 Views)
08-19-2012 05:30 AM in reply to: tbabcock123
The same problem here on a Macbook Pro Retina. The files open fine however on the iMac. Both are running Mountain Lion.
Employee
Macro.Liu_Autodesk
Message 5 of 55 (2,433 Views)
08-19-2012 06:49 PM in reply to: tbabcock123
Thank you for all the information! We're tracking this issue right now and will try to provide a solution in the future.
Macro Liu
bentwookie
Message 6 of 55 (2,416 Views)
08-20-2012 11:21 PM in reply to: Macro.Liu_Autodesk
For what it's worth, here is a very simple save file I can't open anymore without crashing. I don't know if it's related, but I was having a really tough time with sketch dimensions that 1) I couldn't select 2) were affecting the constraints of my model anyway. I accidentally saved while I was in this situation and after that, I couldn't open the file.
Employee
Macro.Liu_Autodesk
Message 7 of 55 (2,410 Views)
08-21-2012 01:17 AM in reply to: bentwookie
Thanks for your sharing! All the information and the dataset are valuable for us to track it down and work out a solution.
Macro Liu
New Member
jpmurph7
Message 8 of 55 (2,400 Views)
08-21-2012 08:40 AM in reply to: tbabcock123
I have experienced the same issue, several times. It seems to happen once fusion crashes while working on the file. Once I close, send error report, reopen fusion, reopen file I was just working on >>> spinning beach-ball crash.
It seems like the file is somehow corrupted. It even changes the thumbnail preview of the file type on my desktop here  (not working file is on the right)
I have deleted and reinstalled inventor fusion 3 times, which has not helped.
OS X 10.7.4 8GB of Ram
New Member
jdzike936
Message 9 of 55 (2,348 Views)
08-27-2012 05:04 AM in reply to: jpmurph7
THNKS FIOR SHARING
read more about dessert recipes
New Member
Wintaru
Message 10 of 55 (2,334 Views)
08-28-2012 04:28 AM in reply to: tbabcock123
Mine is crashing too, I'm trying to select a surface to draw a line off of.  Actually most commands that I try seem to crash the application now.  Attached is the drawing file and crash report.
It seems like it's trying to do something graphics related, or at least if I let the spinning beachball of death continue to spin rather than force quit it, that part of the Mac gets hot and the fans start up.
I'm using a 2011 MacBook Pro 17" model with the Radeon 6750m.  The other system specs are:
Model Identifier: MacBookPro8,3
Intel Core i7 2.2ghz
4GB RAM
180gb Intel SSD 520
Let me know if there is anything else that would be helpful for you.
Edit: Apparently your forums don't allow files with f3d extensions, so when you download OfficeShelf.txt, rename the extension to .f3d to open it.
