Hi, somebody help please. I used some older versions of Inventor. In this new program when I start sketching I don't get the display part where you put the dimension, there is a white prompt indicating "enter the dimension" but you don't have where to put it, so you don't have a chanse to draw a circle of the dimention you need.
Thanks.
For your problem. If you want just create a circle with your dimension, you can try below workflows:
1.Invoke Circle command;
2.Click any point of the sketch area;
3.Move the mouse somewhere;
4.Input value you want;
5.Click again;
6.Double click the circle you created, now you can edit the value of it.
You also can refer to Fusion help here:
http://wikihelp.autodesk.com/Inventor_Fusion/enu/2013
Hope this solve your problem.
