Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
Inventor Fusion 2013 Will Not Load
22 REPLIES 22
Message 1 of 23
engineer968
3318 Views, 22 Replies
Fusion 2013 will not load regardless of running it from within Inventor or on it's own. There is no error message. It begins to load up and then simply evacuates from memory as if it had never been run in the first place.
I have tried to run it as administrator with no change. I have uninstalled and reinstalled it with no change.
Inventor 2013 runs flawlessly as does the rest of my Autodesk Product Design Suite.
Any help would be greatly appreciated.
22 REPLIES 22
Message 21 of 23
Sofashee
in reply to: Phil.E
Hi, I just tried the Finder>Go>Go
  1. First, log on to your account.
  2. At Finder>Go>Go to Folder, enter: ~/Library/Application Support/Autodesk
  3. Look for the folder called Inventor Fusion
  4. Delete it
  5. Start Fusion
It says the folder cannot be found.
Now what?
Message 22 of 23
Phil.E
in reply to: Sofashee
Can you browse, or use Go > Go to Folder, and find ~/library?
Manually browse to the Application Support folder
Manually browse for the Autodesk folder inside
Do you find a folder in Application Support called "Autodesk"?
Phil Eichmiller
Software Engineer
Quality Assurance
Message 23 of 23
Sofashee
in reply to: Phil.E
I went to the Application support folder and there is no folder for Autodesk.
