Inventor Fusion
Inventor Fusion
Board Manager
63 Kudos
Post 11 of 23
Re: Inventor Fusion 2013 Will Not Load
08-01-2012 03:40 PM in reply to: kovir
Just to be clear: please confirm whether or not you downloaded Fusion again.
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
Active Member
0 Kudos
Post 12 of 23
08-01-2012 03:55 PM in reply to: Phil.E
Yes, I downloaded it again via app store
edit: I launched Inventor Fusion on my wife's account and it starting normally... On my account it crashes.
Board Manager
63 Kudos
Post 13 of 23
08-01-2012 04:45 PM in reply to: kovir
Kovir-
That's good news that it runs on your wife's account. We can try two things.
Let's get rid of some of your user account files that may be causing problems. (don't worry, Fusion will replace them when it starts)
  1. First, log on to your account.
  2. At Finder>Go>Go to Folder, enter: ~/Library/Application Support/Autodesk
  3. Look for the folder called Inventor Fusion
  4. Delete it
  5. Start Fusion
If this doesn't work, try this:
If you have an Autodesk 360 account, log out of Autodesk 360 and try Fusion again.
I hope this helps.
Phil Eichmiller
Active Member
0 Kudos
Post 14 of 23
08-02-2012 12:17 AM in reply to: Phil.E
Deleting folder Inventor Fusion helped :smileyhappy:
Thank You very much for Your help
New Member
0 Kudos
Post 15 of 23
08-11-2012 04:08 AM in reply to: Phil.E
I download Inventor Fusion 2013 ... installed ... but when you start, open the drawing area, write me message "inventor fusion.exe stopped working". Before that I had a trial version of Autodesk Inventor 2012 x64. I work with Windows7, 2.1GHz, 4GB RAM. Please help (new download, repair program??) Thank you
Employee
6 Kudos
Post 16 of 23
08-14-2012 10:49 PM in reply to: Mat.design
Did you ever try to install Inventor Fusion 2013 on another machine or clean OS? If it works well, then the downloaded installer should be just fine.
Please let us know the result if you're able to have a try.
Macro Liu
Inventor Fusion QA Team
New Member
0 Kudos
Post 17 of 23
Inventor fusion 2013 wont open
10-10-2012 12:26 PM in reply to: engineer968
I downloaded the free version of inventor fusion 2013 64bit. My PC is very good and I cant understand why it wont work
When I run the program either in noraml mode or admin mode is crashes before any splash screens. It sometimes says that there was an error. So I reinstalled the program to my primary hard drive and now it does not load at all. And it does not give any error messages. I have Win 7 64bit. I am wondering wether i get the 32 bit I will have better luck.
Please help. I have spent over a week trying to get the programm to load to no prevail.
New Member
0 Kudos
Post 18 of 23
12-06-2012 10:13 PM in reply to: engineer968
           I too have a problem when I just downloaded Invetnor Fusion it didnt load or run it just said " There was a error while Initializing the Graphic Subsystem"
            Can Some one Please tell me or even help me with this?
Member
0 Kudos
Post 19 of 23
09-28-2013 02:03 PM in reply to: Phil.E
I'm having a similar issue.  I installed last december from the mac app store and have had no problems until today.  I tried to open the program and it crashed. I tried restarting my computer (macbook air) and got stuck in a loop of "the last time you opend Inventor Fusion, it unexpectedly quit while reopening windows. Do you want to try to reopen its windows?" I press reopen and it brings up "Inventor Fusion quit unexpectedly. Click reopen to open the application again. Click report to see more detailed information and send a report to Apple."
When I click "reopen" It brings me back to the first window .
I tried reinstalling the app and restarting the computer and it goes right back to the same infuriating loop of unhelpfulness.
Member
0 Kudos
Post 20 of 23
09-28-2013 03:09 PM in reply to: kovir
the same happened for me
