Inventor Fusion
Member
engineer968
Message 1 of 23 (1,393 Views)
Inventor Fusion 2013 Will Not Load
1393 Views, 22 Replies
07-24-2012 09:46 AM
Fusion 2013 will not load regardless of running it from within Inventor or on it's own. There is no error message. It begins to load up and then simply evacuates from memory as if it had never been run in the first place.
I have tried to run it as administrator with no change. I have uninstalled and reinstalled it with no change.
Inventor 2013 runs flawlessly as does the rest of my Autodesk Product Design Suite.
Any help would be greatly appreciated.
Board Manager
Phil.E
Message 2 of 23 (1,373 Views)
Re: Inventor Fusion 2013 Will Not Load
07-27-2012 02:15 PM in reply to: engineer968
Is this the first installation of Fusion on this machine? Did you have Product Design Suite 2012 or a Fusion technical preview installed previously?
Phil Eichmiller
Quality Assurance Team
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
Active Member
kovir
Message 3 of 23 (1,325 Views)
08-01-2012 03:28 AM in reply to: engineer968
I have the same....:smileysad:
Few days was OK ( if I can say 1 crash per hour is OK...) but now crash on splash screen... Reinstallation won't to help...
New Member
Duohsoft
Message 4 of 23 (1,318 Views)
08-01-2012 09:08 AM in reply to: engineer968
Hi !
Have the same problem - Inventor Fusion 2013 hangs during installation, never loads...what can I do ?
How do I remove it ?
Board Manager
Phil.E
Message 5 of 23 (1,312 Views)
08-01-2012 09:19 AM in reply to: Duohsoft
kovir, and Duosoft,
Phil Eichmiller
New Member
Duohsoft
Message 6 of 23 (1,310 Views)
08-01-2012 09:47 AM in reply to: engineer968
Hi !
Yes... I re-started my Mac (OSX Lion), went to Launcher and found that the installation  / download had stopped.
Re-started the download / install and was able to fullfill the installation process !
Nice UI in IF 2013 ...
Thanks !
Active Member
kovir
Message 7 of 23 (1,307 Views)
08-01-2012 10:19 AM in reply to: Phil.E
Yes, this is first installation. I think it was started when I installed a trial of Autocad for Mac ( now I know that Autocad don't run on Mountain Lion...)
Board Manager
Phil.E
Message 8 of 23 (1,300 Views)
08-01-2012 11:21 AM in reply to: kovir
You should try a fresh download/install of Fusion.
Go here to download your new copy of Fusion and try again.
If it doesn't work, please respond with the steps you took and details about your system.
Phil Eichmiller
Active Member
kovir
Message 9 of 23 (1,286 Views)
08-01-2012 02:58 PM in reply to: Phil.E
Reinstallation didn't help... I have a message windows ( on splash screen) :" the last time you opened Inventor Fusion it unexpectedly quit while reopening windows. Do You want to try to reopen its windows again? ..."
I may too choose Reopen or Don't Reopen - it crash every time.
I reinstalled Inventor Fusion but this message apeared again...
Active Member
kovir
Message 10 of 23 (1,285 Views)
08-01-2012 02:59 PM in reply to: kovir
Macbook Pro 7.1  Mountain Lion, 8GB RAM, CUDA 5, NVIDIA 320M
