Inventor Fusion
Inventor Fusion
Active Member
0 Kudos
Post 1 of 14
Inventor Fusion 2013 R1 Not Launching...
5120 Views, 13 Replies
10-28-2013 11:32 PM
Good evening everyone. I recently installed quite a few Autodesk products, but came to an issue with Inventor Fusion 2013 R1. I installed it from CFD, and the installation was successful, but whenever I try to launch Fusion, it fails to open the program.. I'm having the same problem with Inventor View 2014. And also, whenever I try to launch Simulation Mechanical 2014, I receive the following message:
"You are attempting to run a version of Autodesk Simulation other than the one last registered on this sytem (C:\Program Files\Autodesk\Simulation 2013\AlgFrame.exe).
Would you like to try to register this version now?"
Upon which I'm greeted with numberous attempts to make registry changes, ultimately resulting in an error:
"Unexpected error; quitting"
"The registration attempt was not successful. You may not have premission to register applications on this system. If you still would like to register this version of FEMPRO, use the Add/Remove Programs option in the Control Panel and select the 'repair' option.
It should be noted that I am also running Windows 8.1 64-bit, if that helps.
Any assistance would be great! ^_^
Employee
48 Kudos
Post 2 of 14
Re: Inventor Fusion 2013 R1 Not Launching...
10-29-2013 05:59 PM in reply to: isgellma
Hi isgellma,
  I'm pretty sure that there are very few (if any) Autodesk products that are supported for use with Windows 8.1 yet.
  That said, before installation did your user account have administrative privileges and did you have any anti-virus programs disabled?
  From the error message, it sounds like your account doesn't have the administrative privileges needed to modify the registry.
Hope this helps...
Best regards, -Hugh
Hugh Henderson
Simulation QA Engineer
DLS
New Member
0 Kudos
Post 3 of 14
10-30-2013 06:19 PM in reply to: henderh
I have the same issue. I used Inventor Fusion R-1 before upgrating to Windows 8.1. Now it doesn't start. I have administrator right and try everythings. Inventor Fusion needs to fix.
Active Member
0 Kudos
Post 4 of 14
11-02-2013 09:50 AM in reply to: isgellma
Yeah Inventor Fusion 2013 R1 needs to be fixed. So far that's my only issue on 8.1. I managed to get everything else working, except for Fusion 2013 R1. Also having an issue launching Inventor View 2014, that was bundled with Inventor 2014 Pro, but that's for a different fourm posting :smileyvery-happy:
Any suggestions?
Active Member
0 Kudos
Post 5 of 14
11-02-2013 09:52 AM in reply to: isgellma
Oh yeah, henderh, I managed to fix that error by removing Multiphysics 2013 and reinstalling Simulation 2014. Had no idea they conficted. Thanks!
Employee
48 Kudos
Post 6 of 14
11-04-2013 08:54 AM in reply to: isgellma
Hi isgellma,
  Many thanks for the follow-up and additional info!  I'll forward the Win 8.1 issue to the Inventor Fusion folks in case it's not known yet.
Best regards, -Hugh
Hugh Henderson
DLS
New Member
0 Kudos
Post 7 of 14
11-05-2013 06:53 AM in reply to: isgellma
Isgellma, any progress with getting inventor fusion R1 to launch in Win 8.1?
Active Member
0 Kudos
Post 8 of 14
11-12-2013 07:17 PM in reply to: tkole16
Still no luck with fusion, I'm afraid. Hopefully a patch will be released soon *fingers crossed*
New Member
0 Kudos
Post 9 of 14
11-22-2013 07:29 AM in reply to: isgellma
Has anyone heard anything about a fix for Inventor Fusion (AutoDesk Fusion 360) in Win 8.1?
New Member
0 Kudos
Post 10 of 14
01-10-2014 02:30 AM in reply to: isgellma
I refresh question ... !!! ??? Fusion 2013 in windows 8.1... ???
