I have alot of drawings saved that were created in inventor fusion. Im having trouble opening them up in inventor 2015. When I open them up they are in wire frame. I need to convert them back to solid. I lost my fusion copy and cant find it to replace. I need to modify some of my old drawings. Attached is a copy of a file I need to convert. Thanks in advance
I think you are importing the wrong way. In the open dialog when you select the dwg file at the bottom you have to click in options, then choose import, and finally open. It will take you through some configuration windows, follow the steps.
Regards.
Fernando.
