Inventor Fusion
New Member
0 Kudos
Post 1 of 7
Importing dwg files
969 Views, 6 Replies
08-25-2012 02:35 PM
I have two files that I created in illustrator that I would like to import as a sketch in IF, but I keep getting a "load dwg file failed."  What can I do to get these files to work? I am doing a project for my dad, and want to be able to use this program to complete it.
Hi
If you want to open the 3D models which are created by Sketchup (.skp file) or SolidWorks/Catia/Proe, you don't need to translate to dwg file, Fusion can open many kinds of format files.
If you want to using a sketch create by AutoCAD, you can copy the sketch lines and Paste to Fusion sketch.
If you are using a high Revison solidworks/Catia/Proe which is beyand our limit, you can save 3D model to step/stl format, Fusion can open them very well.
Cathy
Autodesk, Inc
(Please mark this response as "Accept as Solution" if it answers your question)
2,120 Kudos
Post 2 of 7
Re: Importing dwg files
08-28-2012 01:12 PM in reply to: alexhberger
When I open the files in AutoCAD I get an warning and on inspection see some areas that are duplicated (right side of image) and/or not very good quality (left side of image).
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
2,120 Kudos
Post 3 of 7
08-28-2012 01:18 PM in reply to: JDMather
I would attempt to use far fewer points to define spline curves (see image where one point does good job of defining curve) and use lines and arc segements where possible rather than splines.  Also note the point circled in red.
2,120 Kudos
Post 4 of 7
08-28-2012 01:22 PM in reply to: JDMather
In this image I didn't move it completely into an aesthetically pleasing position, but you should be able to see how it was way out of position from previous image.
Board Manager
63 Kudos
Post 5 of 7
09-04-2012 05:32 PM in reply to: alexhberger
In my experience the DWG data created by Illustrator is often prone to this kind of defect. Illustrator tends to generate graphics that look okay, but are not robust enough for 3D modeling without an edit session in AutoCAD.
Fusion can import an image as a Canvas and you can sketch on top of this. Have you tried this?
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
Valued Contributor
0 Kudos
Post 6 of 7
09-15-2012 01:26 PM in reply to: Phil.E
Inventor Fusion has a hard time using DWG files that were not created in Autodesk products such as .dwg files in Solidworks.
Employee
1 Kudo
Post 7 of 7
09-16-2012 07:05 PM in reply to: mailswamp
Hi
Cathy
Autodesk, Inc
Cathy Wang
Fusion 360 Quality Assurance Team
