hi,
I want to cut a model by moving the machine axis manually (Machine assembly done by us eg. milling machine).Can any one tell me the method please.
Manikandan_77@yahoo.in
There is no way to create a cut directly from moving a tool through an object.
You can, however, create a cut that mimics the path of a tool by using the Sweep command.
First sketch the tool path. Then in a new sketch, sketch the profile of the tool and link it to the path by using Project Geometry.
Use Sweep command and pick the path and profile to make your cut.
Does this sound like what you need?
