I'm running Fusion TP on the Mac (Thanks!) and have both an array of identical components and some hand duplicated components. I've searched and found a forum thread that said that components in an array (for one of your products) couldn't be made independent. But what about the individually copied and pasted components?
I note that 123D has both a "Paste as Independent" option and a "Make Independent" command, but can't find anything similar in Fusion TP. Even tried "Make Component from Bodies", but no joy.
Is making a component independent just not implemented yet in Fusion TP?
Mike
PS: Is this the right place for Fusion TP Mac questions?
Solved by schneik-adsk. Go to Solution.
Yes this is the correct place to post.
And yes, make independent is not yet in the Mac version. Unfortunately there is not a very good workaround to this limitation.
Here is what I do (for now).
Create an empty component in the browser.
Go to the body I want to reuse.
Edit -> Copy from the menu bar.
Select the newly create component.
Edit -> paste.
The body should appear in the new component and be independent from the source.
Kevin,
Thanks for the reply. Confirms my suspicion And for confrming that the workaround I found is the currently optimal way.
Mike (who's making prgress getting his head wrapped around Fusion and using it to solve some mechanical linkage problems)
