Announcements
Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
How to do threads with Inventor Fusion?
7 REPLIES 7
Message 1 of 8
fsamir
6608 Views, 7 Replies
Hi there,
is it possible to create threads with Inventor Fusion? Any workaround?
It seems is a killer feature that is missing.
Franklin
7 REPLIES 7
Message 2 of 8
Phil.E
in reply to: fsamir
Franklin,
Thanks for posting. You are correct, threads are a great feature. Can you describe how you would use the threads?
Thanks!
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 8
fsamir
in reply to: Phil.E
I would like to use to connect thing, like a jar lid, screws, etc.
It would be great if we were able to apply a positive thread externally to
a cylinder and substract the same thread from another shape, so they could
connect to each other.
Franklin Dattein
Message 4 of 8
Phil.E
in reply to: fsamir
Franklin,
I'm sorry I should have been more clear. By "use the threads" I mean: do you need a 3D model, or just a picture, a 3D printed model, or a drawing of the parts?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 8
fsamir
in reply to: Phil.E
I can think of some different ways to achieve the job. Please let me know if it is clear enough.
1. Using sketches
Given a 3D object (like a cylinder) I would like to be able to apply a thread sketch to its surface,
in such a way that I can define thread thickness, distance between threads, thread angle
And pull it up in such a way that it will add threads to the surface of the object
Or pull it down in such a way that it will substract the thread to the surface of the object.
2. Using a 3D object
Given there is a new Thread 3D Object model in the menu
When I choose it
Then it render the object like an spiral
And I can define the following parameters:
  thread thickness;
   distance between threads;
   thread height;
   thread angle
And I can snap it to an existing 3D object
And I can subsctract it from an existing object.
3. Modifying an existing object (similar the holes functionality)
Given I have an 3D object that supports threads (like cylinders and cilindircal holes)
When I select the object surface
Then there is an option to apply the thread pattern to the selected object's surface.
And I can specify the following parameters:
   thread thickness;
   thread height;
   thread angle
Message 6 of 8
Phil.E
in reply to: fsamir
Franklin,
Thanks for letting us know how you would like to use threads.
Inventor Fusion does not support such features. However, Fusion 360 does.
Fusion 360 has a thread command that:
  • Has physical (3D) and graphical threads
  • Threads are specified by picking the size and standard
  • Geometry adjusts to the thread size.
Try it here: Fusion 360 Hub
Thanks again,
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 7 of 8
fsamir
in reply to: Phil.E
Hi Phil,
thanks for ponting to Fusion 360.
I just downloaded it and I managed to create threads just as I was looking for. I hope when Fusion 360 becomes a payed software it won't be too expensive for a hobbist like me.
Message 8 of 8
Phil.E
in reply to: fsamir
Franklin,
There are three worspaces. Threads are in the Model workspace, which is for traditional 3D solid modeling. I suspect you are in the Sculpt workspace.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
