Inventor Fusion
Inventor Fusion
Member
Sarz91
Message 1 of 11 (565 Views)
Having trouble with Inventor Fusion.
565 Views, 10 Replies
09-02-2012 10:34 AM
I recently downloaded the student edition of Simulation CFD. Inventor Fusion came with it. I use Creo 2.0 for most of my college work and also have it donwloaded on my computer. My problem is anytime I try and open one of the Creo 2.0 files in Fusion, it either crashes or freezes. I can open the sample model no problem but then when I try to run some tests on it in Simulation CFD that program becomes unresponsive.
I only just built up my system about a month or two ago.
I'll list the specs anyway:
-CPU: I5 3570K overclocked to 4.2 GHz
-Ram: 16 GB ddr3
-GPU: GTX 670
-PSU: 650 Watt Amazon Super Flower
-Primary Memory Storage unit: Samsung 830 series 128GB
-Secondary Memory Storage unit: Seagate Barracuda 7200 rpm 1TB
I've uninstalled and re installed a few times. Any help would be greatly appreciated.
Employee
Mike.Zhang
Message 2 of 11 (543 Views)
Re: Having trouble with Inventor Fusion.
09-03-2012 01:42 AM in reply to: Sarz91
Could you tell me which OS you are using now to run it?
Win7-64bit OS or Win7-32bit OS?
And could you send me your models which opened in Fusion?
You can attach them here or mail to me:
jiangang.zhang@autodesk.com
Mike.Zhang
SQA Engineer
Fusion 360 Quality Assurance Team
New Member
alper
Message 3 of 11 (532 Views)
09-03-2012 08:40 AM in reply to: Sarz91
I have same problem, system
İmac
21.5-inch, Mid 2010
3,06 GHz Intel Core i3
8 GB 1333 MHz DDR3
ATI Radeon HD 4670 256 MB
OS X 10.8.1 (12B19)
Member
Sarz91
Message 4 of 11 (528 Views)
09-03-2012 10:44 AM in reply to: Mike.Zhang
My OS is Win 7 64 bit. I sent you the model. Its just a rectangular shaped solid. I can open the part in fusion using the NX translator but the part doesn't appear and Fusion closes shortly after. If I try the ProE translator I get the following error message and then Fusion instantly closes Error: Unhandled Exception. I can open the sample model with Fusion but when I bring it across into simulation CFD both programs become unresponsive and close.
Employee
Mike.Zhang
Message 5 of 11 (519 Views)
09-03-2012 07:18 PM in reply to: Sarz91
Hi Sarz91,
Tanks your replyment, we'll analyze it.
I haven't recieved your mail with model now, could you attach the model here?
Mike.Zhang
SQA Engineer
JDMather
Message 6 of 11 (503 Views)
09-04-2012 09:21 AM in reply to: Mike.Zhang
Does Fusion support Creo 2 (or only Creo 1)?
I tried a Creo 2 file and Fusion 2013 crashed here as well.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Employee
Mike.Zhang
Message 7 of 11 (490 Views)
09-04-2012 11:09 PM in reply to: Sarz91
Fusion doesn't support Creo files.
You can find the detail information here.
http://wikihelp.autodesk.com/Inventor_Fusion/enu/2013/Help/0167-Import_D167
Mike.Zhang
SQA Engineer
JDMather
Message 8 of 11 (483 Views)
09-05-2012 05:26 AM in reply to: Mike.Zhang
Mike did you try it?
Fusion imports Creo 1.0 files on my machine just fine.
The Inventor Help files are out-of-date (as usual for Autodesk).
Creo Parametric  is the new name of Pro/Engineer.
Creo 2.0 came out after Fusion 2013, but Creo 1.0 files translate fine.
You can try it yourself with the attached Creo file.
Employee
Mike.Zhang
Message 9 of 11 (465 Views)
09-05-2012 10:33 PM in reply to: JDMather
Thanks your replyment.
Yes, I also can open your Creo 1.0 file by using Fusion 2013.
Seems the file type of Creo1.0 file is same/similar as Proe4.0 file. So we can luckly open it by Fusion 2013.
But Fusion just clarified it supports Proe file type up to version 4.0.
Types of Pro/ENGINEER files you can import:
  • *.prt* (part) (up to version 4.0)
  • *.asm* (assembly) (up to version 4.0)
  • *.g (Granite) (up to version 5.0)
Mike.Zhang
SQA Engineer
Member
Sarz91
Message 10 of 11 (457 Views)
09-06-2012 05:10 AM in reply to: Mike.Zhang
So Fusion 2013 doesn't support Creo 2.0 parts? Is it the same with Simulation CFD?
