Inventor Fusion
New Member
ScissorCrow
Message 1 of 2 (447 Views)
Graphics Subsystem Error
447 Views, 1 Replies
05-15-2013 03:33 AM
Hi, I am  a non user trying to solve this issue for my brother. He uses Autodesk Inventor Fusion 2013 on a shared computer and I recently deleted some files and now when it loads it displays:
"Runtime Error! Please repair or reinstall the program.
    We’re sorry, there was an error while initializing the graphics subsystem.  This is likely due to one or more of the following:  your graphics driver is not configured for "True Color", there was a problem installing the application, the application installation was damaged, or some other problem with the graphics hardware and drivers or the configuration of the application.  More detailed information may be included below."
I have read other threads with the same error, but as they were new installs and this was working previously I started a new thread.
I am pretty sure I didn't delete any CAD files, Design Review and AutoCAD 2013 still load properly.
What could I have deleted/uninstalled?
We use a NVIDIA GeForce4 MX 4000 on Windows XP
Don't have Windows 7 or Aero so can't disable it.
Display Settings doesn't have a True Color option, only Medium(16bit) and Highest(32bit)
If he does have to re-install the program we can just make copies of the drawing files somewhere and open them after re-installation, right?
Thanks for reading.
Board Manager
Phil.E
Message 2 of 2 (432 Views)
Re: Graphics Subsystem Error
05-21-2013 03:43 PM in reply to: ScissorCrow
Going through control panel/uninstall, look for a repair option. Barring that, I would try to re-install Fusion. The data files (.dwg) that you have are portable, and I assume you keep them stored separately from the program files so they won't be accidentally deleted. If it worked before, then it's likely it will work again after repair or re-install.
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
