Announcements
Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
Getting Constraint to work.....
1 REPLY 1
engineerboy
409 Views, 1 Reply
Has anybody got the constraint feature to work with multiple bodies (parts).
Steve
1 REPLY 1
schneik-adsk
in reply to: engineerboy
When you use the constraint command there are two choices: Body constraints and Component constraints. Component constraints are very similar to those that you might use in Inventor assemblies and can be applied across components for the purpose of positioning.
Body constraints can be applied to a body and can force geometry on the body to keep a specific geometric relationship.
Try creating a new document and model a simple block. Make sure two side of the block are not parallel.
Next, use a parallel body constraint on these two faces and you will see the body update to keep this new relationship. Even of you use the move tool on either face and rotate, you will see both faces will move.
-Kevin Schneider
Kevin Schneider
