I absolutely have no idea what's up.
New Fusion TP4 install on Brand new Win 7 64 os, new Inventor Pro install.
Runs (slowly) at office in docking station, but will NOT run when at home office, no dock.
Gets to splash screen, and then crash.
Any ideas at all? I have uninstalled, reinstalled. Repaired. Always the same.
I am experiencing the same, I have submitted a support request from the CER. This has been happening since I tried to install TP3. This also occurs on TP4 and the latest (I am a support tech at a reseller).
I have uninstalled, reinstalled, cleaned the registry and folder structures with no luck.
Can you give some details about your graphics card?
Alos, in widows file explorer address bar type %appdata%, find the Autodesk folder and then any Fusion folder and delete them.
Try starting Fusion again. We are sorry you are having these problems.
-Kevin Schneider
Hi Kevin,
Have just deleted the %appdata% items and I require a restart. My graphics card is a Quadro FX1600m in a Dell Precision m6300. I am trying to get my boss to get me a new one but this is hard going as a reseller...
Have restarted and there is no change to the startup CER.
This happened with TP4 but also now with 2012...
Hay help would be greatly appreciated.
John
Did you submit a CER? If so, can you send me your email address and I will look into the issue for you. My email address is kris.berg@autodesk.com.
Thank You,
Kris Berg
Fusion Development
Hi John,
Sorry to hear you are having problems with Inventor Fusion. I have searched the CER system and can not find any recent CER's from you. The last one I can find was sent on 12/10/10. Can you send another CER using Inventor Fusion 2012?
Thank You,
Kris Berg
Fusion Developer
I have just tried reinstalling it after using the 2012 inventor uninstaller, and now it runs... Thanks for all of your help.
